Darrieus Wind Turbine - 2d CFD , abnormal results
Old   March 24, 2019, 02:21
Angry Darrieus Wind Turbine - 2d CFD , abnormal results
Anonymous
freekytr is on a distinguished road
Hello. We are trying to simulate darrieus wind turbine's rotating and find CM values.
But there is a problem. We trying to compare with experimental studies.
In experimental studies, chord lenght 0.265 m, blade height 1.2 m and rotor dia. is 2 meter.
So, in our study, we draw with 2 bades darrieus. Of course, we cant give a height to the blades, because we working 2d.
Okey, we have 300000 mesh, sst k-w, transiet, mesh motion and give radial speed to the ring, others are fixed, and we have 8 m/s inlet wind speed, turbulance indensity 0.5 and lenght scale 0.0265m, blades are moving.
But our results are too high from expected, sometimes too low. We try to catch 0.1 Cm value, because in experimental study Cp is 0.2 and TSR = 2
So, could be an error with our reference values ?
Area = Diameter * Height = 2 m * 1,2 m
Depth = Height, 1,2 m
Lenght = Radius of rotor, 1 m
I checked everything, interfaces, domain properties etc. But i dont understand what is the mistake.. Here is a picture, for 8 hours fluent could solve only for 240 degree, of course blade has to rotate 6-7 tours to be stationary but when i see this, i think it is impossible to catch 0.1 avarage value. It is still solving by the way
Best regards, hope i can find an advice
freekytr is offline   Reply With Quote
cfd, darrieus, vawt
Import external CFD results into Autodesk CFD for visualisation julien.decharentenay Autodesk Simulation CFD 0 May 31, 2014 20:16
Savonius Wind Turbine CFD amianjan FLUENT 0 February 16, 2014 07:27
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 04:09
need wind turbine data for cfd validation Reggio Main CFD Forum 0 September 9, 2012 11:30
ICEM CFD creating the grid of a Wind Turbine blade Dan CFX 11 June 1, 2012 14:11
