Problem which has both laminar and turbulent flow |
June 13, 2019, 22:38 |
Anonymous
Rep Power: 12 |
Hi guys,
What kind of turbulence model you suggest in a problem where both laminar and turbulent flows exist in the same system. I've searched around a bit and learned a bit on Transition SST but it only talks about external and flow separation problems, what's the alternative for internal flows like ducts. pipes etc.? Thanks! |
September 17, 2019, 05:17 |
Sai Krishna
Rep Power: 7 |
Intermittency transition can help you
September 17, 2019, 09:11 |
Rep Power: 13 |
How sure are you that you have both types of flows?
How far off is a standard turbulence model to your data? 1) Use a Intermittency transition model. or 2) Define a region where you don't model turbulence. |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 07:45 |
how to solve a problem involving both laminar and turbulent flow | seefd | FLUENT | 1 | June 3, 2011 03:20 |
