help with question
Old   August 24, 2019, 15:46
Default help with question
mahdi
Optzero is on a distinguished road
  1. Critical assessment of the y+ and different near wall treatments in CFD modelling of turbulent flows involving no-slip wall boundary conditions.
  2. Comparing the results and critical assessment of the performance of k-epsilon and the Reynolds stresses turbulence models for CFD modelling of the atmospheric air flow in the annular space between two pipes with the following geometry and boundary conditions: annular space between two pipes with inner diameter of 120 mm, outer diameter or 140 mm, and pipe length of 10 m; the inlet air mass flowrate of 0.3 kg/s at temperature of 25 C, inner wall is adiabatic, and the outer wall is at a constant temperature of 600 C
how do i go about doing this?
Optzero is offline   Reply With Quote
Old   August 24, 2019, 18:23
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
It usually goes a little something like this: apply the knowledge you gained in that course to do the homework for said course.
Seriously, if you have any specific question, I am sure people here are willing to help. But just copy&paste your homework is not how forums work.
flotus1 is offline   Reply With Quote
Old   August 24, 2019, 20:03
mahdi
Yeah fair enough, I'm familiar with modelling k- epsilon but I don't know how to model the Reynolds stress turbulence in fluent.
Thanks for any help
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
