September 25, 2019, 11:08 |
Defining radiation for solid air
sunil
Rep Power: 13 |
Hi All,
In my analysis, the convection heat transfer is very negligible compared to conduction and radiation. I am modeling fluid domain with the properties of air but I am defining it as a solid. I know that if I define a fluid domain as solid with air properties then conduction heat transfer will be accounted. If I want to calculate radiation heat transfer between the fluid surfaces (which is defined as solid) then how can I do it in FLUENT. Thank you in advance Sunil
Regards, Sunil |
solid air |
viewFactor radiation model stuck | shach934 | OpenFOAM | 1 | May 25, 2021 11:01 |
Defining Cp for air | nived | FLUENT | 6 | March 27, 2018 10:59 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 05:41 |
Radiation through: glass – air cavity – glass | Yingchun | CFX | 7 | February 27, 2012 16:46 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
