October 14, 2019, 17:32 |
Air flow simulation
Rep Power: 6 |
hello folks,
in design modeller, i developed a closed domain (oven) basically involving an impeller in a rotating domain enclosed in stationary domain (oven cavity), necessary operations have been performed like 2 boeleon operations (impeller from rotating domain; and rotating domain from stationary domain). i also took the liberty to scale down the rotating domain by 0.997 to avoid the warning of "overlapping mesh interface..." during fluent setup. in my mesh, unfortunatly, i'm using ANSYS R19.0 academic so i am limited to 512000 elements but i was able to perform some operations like creating a body sizing(30mm) on the oven cavity; body sizing (10mm) on the rotating domain and also perform refinement (1) on one face and the body of the rotating domain. in the fluent, my model is mainly steady, turbulence model (relizable k-e standard wall), i set the cell zone condition for the rotating domain, my boundary condition are just wall condition (closed domain). my solution method scheme is coupled. but my problem here now is my convergence. my simulation is finding it hard to converge. pls i am sorry for the long epistle, what can be done to force convergence.please folks, i need help asap. pictures needed are below. |
October 14, 2019, 23:42 |
Svetlana Tkachenko
Rep Power: 14 |
what is the rpm, velocity magnitude
October 15, 2019, 02:10 |
Rep Power: 6 |
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) | remidemol | OpenFOAM Running, Solving & CFD | 3 | May 26, 2020 05:47 |
Air flow and blower simulation | ati_ros61 | FLOW-3D | 2 | November 19, 2019 11:32 |
Simulation of a flow from a syringe into air | ydima | FLUENT | 79 | August 30, 2019 01:29 |
Multiphase flow - simulation crashing | yschati | CFX | 14 | November 16, 2010 17:29 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
