Shadow Faces in Fluent
Like Tree1Likes
  • 1 Post By jyothishkumar
Old   May 13, 2005, 18:42
Default Shadow Faces in Fluent
Kjt
I have created a mesh in gambit in which I have a solid zone adjacent to a fluid zone. When I import this mesh to fluent, I get a wall and a wall-shadow between these 2 zones. so now the sequence of the boundary is: solid interior, wall, wall-shadow, liquid interior. What is this wall-shadow zone and why does Fluent create this? Also, what material property should I assign to these zones (wall amd wall-shadow)..solid or liquid?. Any help would be highly appreciated. Thanks
Old   May 16, 2005, 06:42
Default Re: Shadow Faces in Fluent
jyothishkumar
hi, u must be doing some heat transfer problem. In that case v have to mesh both the solid and fluid zone. fluent will automatically couple this fluid and solid zone through this shadow faces. If u take a solid adjacent to fluid, which is having contact with fluid as well as with solid(there will be a common face). so it divides that face in to two faces one which is in contact with solid zone and the other which is having contact with fluid zone.
bye
jyothish
pezarello86 likes this.
Old   May 16, 2005, 17:26
Kjt
Thanks for the reply. What would be the case in which both the zones are solid? Which solid'sproperty should I assign to the wall and the wall-shadow?
Old   May 17, 2005, 00:15
jyothish
hi,
If both the zones are solid then u r doing conduction problem. Generally for wall and wall-shadow u can give the thickness or u can leave it as it is.
bye
jyo
Old   October 14, 2013, 05:51
Kishan Kumar Jaiswal
Kishan is on a distinguished road
what material property should be assign to these zones??
Kishan is offline   Reply With Quote
Old   October 29, 2019, 07:03
Default zones
ssixr's Avatar
sudhir
ssixr is on a distinguished road
hi,
whether you are having solid or liquid, everything is defined in terms of cell zones. if you opened the wall or wall shadow boundary condition, there is an option showing nearby cellzone. i recommend you to use same material as neighboring cell zone.
ssixr is offline   Reply With Quote
Old   November 12, 2019, 07:45
CFD-Lee
AlexLi_AeroEn is on a distinguished road
Originally Posted by ssixr View Post
hi,
Thanks for your answer, so does that mean for a case like solid1-wall-shadowwall-solid2, you can assign solid1 or solid2 to the Material Name in boundary setting, and it doesn't really influence the result since the wall thickness is 0?
AlexLi_AeroEn is offline   Reply With Quote
[Commercial meshers] Fluent Mesh (XP32) to OpenFoam archymedes OpenFOAM Meshing & Mesh Conversion 1 April 1, 2010 05:26
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
Smooth Grid Error! Help seasoul FLUENT 1 March 24, 2008 10:56
How to let Fluent recognize diffrent faces Steven FLUENT 2 March 5, 2003 10:03
