Guidelines for running a mixing plane with a centrifugal compressor |
December 15, 2019, 12:50 |
Andrew
Rep Power: 10 |
Does ANSYS have any guidelines/advice on running a centrifugal compressor with vaned diffuser and a mixing plane? I have been trying to run a high speed centrifugal compressor in Fluent, but my simulation never converges or diverges at some point. There is a large amount of re-circulation at the mixing plane and Fluent is limiting the turbulence viscosity and temperature. I believe it's initial flow field that is causing my problem. I have been able to model an axial compressor with a mixing plane without any issues, and if I use a very coarse mesh for my centrifugal compressor, I'm able to get my simulation to eventually converge. I have read through the Fluent documentation and tried changing the settings for mixing plane, but nothing appears to solve my problem. Does anyone have any advice? Is there any expert parameters hidden in the interface that may help? Thank you, Andrew |
Need help in muti-stage axial compressor simulation using mixing plane | pchoopanya | FLUENT | 0 | July 9, 2018 02:51 |
Problem with Mixing plane | Mitpostdoc | FLUENT | 0 | July 26, 2011 14:31 |
Mixing plane for centrifugal compressor | Mitpostdoc | FLUENT | 0 | March 24, 2011 17:27 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 07:16 |
