Fluent kw-wj-bsl-earsm model
Old   April 9, 2020, 05:20
Default Fluent kw-wj-bsl-earsm model
juies is on a distinguished road
I found that fluent has more turbulence models, which are not displayed on the interface, such as ‘kwi -easm’, ‘ke-easm’, etc. I can use (allow-easm-model) to make the first two available in the interface.
Algebraic Stress Model(ASM) in Commercial Softwares
Now I want to use the "kww -wj-bsl-earsm" model. I have tried some similar commands, but they all failed. Can anyone tell me how to choose this model?
juies is offline   Reply With Quote
Old   April 9, 2020, 05:36
Default Turbulence Model
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Though you can use scheme commands but allow function is not defined for each model. So, you can either use the following command
(rpsetvar 'kw-wj-bsl-earsm-on? #t)
Or just enable beta feature. Enabling beta feature has an advantage because then user is aware that the model is in beta version and not validated as yet.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 9, 2020, 05:52
Thank you for your quick reply, I have tried your suggestion, but it doesn’t seem to change.
Old   April 9, 2020, 05:54
Default Command
vinerm's Avatar
Vinerm
You are mixing two things - TUI and Scheme. Scheme commands are supposed to be used without entering any TUI command. So, come out of TUI commands, i.e., press q until you are in home menu. Or simply enable beta features.
Regards,
Vinerm
Old   April 9, 2020, 13:27
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
The TUI command to enable beta features access is:
/define/beta-feature-access yes ok
The TUI command to turn on kw-wj-bsl-earsm is then
/define/models/viscous/kw-wj-bsl-earsm? yes
LuckyTran is offline   Reply With Quote
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 17:54
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 05:36
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 03:41
How to create a 3Ds Car Model importing to FLUENT? spysunny Main CFD Forum 1 January 10, 2012 23:40
