May 4, 2020, 12:20 |
Absorption in a metal block
Shubh
Rep Power: 6 |
I am simulating hot air passing over a metal block and would like to know how to find out how much heat is absorbed by the metal block in ANSYS FLUENT or POST.
May 5, 2020, 07:52 |
Heat Absorption
In a metal block, it is easy to determine the amount of heat adsorbed. If you are using constant specific heat for the metal block, then all you need to report is volume integral of . If is not constant, then you have to setup a volume monitor for enthalpy of block. This will plot a graph showing enthalpy over time. In the end, just take the area under the curve and that will give you heat content increase over time.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Simulating the Melting of the metal block dropped in Furnace. | ShubhamMane | CFX | 6 | February 12, 2020 06:42 |
[blockMesh] Velocity,Pressure locked in Blocks | Tobi94 | OpenFOAM Meshing & Mesh Conversion | 2 | December 31, 2019 08:27 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
