FLUENT Results and Data Tabulation (Repost)
Old   May 14, 2020, 13:45
Default FLUENT Results and Data Tabulation (Repost)
Syahirah Jaafar
syahirahjaafar is on a distinguished road
Hello there, I hope all of you are doing well. I am simulating hydrogen-enriched methane combustion and I am needed to obtain the temperature at every point (height) of my geometry but I have trouble to do so.
I have attached the picture whereby I need to know the temperature at particular height X. How do I get the datas of temperature vs height (mm)?
Thank you for your assistance.
syahirahjaafar is offline   Reply With Quote
Old   May 14, 2020, 14:46
Default Clarity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Your query is little ambiguous. Do you want temperature at position marked X or temperature vs. height? Both are different. Temperature vs Height will be a graph and depends on whether you are using 2D planar, 2D, axisymmetric or 3D model. It also depends on whether you want spatial averaging in the other direction (other 2 directions if 3D) or not. For position marked X, it is just one value and you can create a point at X and fetch its value.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 14, 2020, 15:03
Smile
Syahirah Jaafar
I see, thank you for your clarification. I am actually required to find the lift-off height of the flame and therefore needed the temperature at every height as a set of data so that I can estimate the lift-off height as well as to study the flame trend in numbers. I am using 2D planar model.
For example:
Height (mm) Temperature (K)
10 1000
15 1230
20 1368
and so on...
I apologize if my question is unclear. Thank you
Old   May 14, 2020, 15:08
Default Data Plot
vinerm's Avatar
Vinerm
There are two ways to extract such data, averaged along the transverse direction and non-averaged values. For flame lift-off, you need to extract non-averaged values. Create a line passing through the flame. This can be done using Surface > Iso-Surface > Mesh > and then select the coordinate that is transverse direction for your case, i.e., the one normal to the flame direction. Choose a value that is somewhere around the middle of the flame. Once iso-surface is created, go to Plots and plot Temperature vs. coordinate on this iso-surface. Within plot, you can choose to Write to File if you want to extract data.
Regards,
Vinerm
Old   May 15, 2020, 17:45
Syahirah Jaafar
Thank you very much for your help, I have managed to extract the data with your help. But can I know how am I able to find the intersections the x and y-coordinate from the plot?
Old   May 15, 2020, 18:10
Syahirah Jaafar
I have figured out the ways to get the datas that I’ve wanted, thank you for your help. Is there any way that I can copy these surface settings to my other cases?
Old   May 16, 2020, 06:28
Default Surface Setting
vinerm's Avatar
Vinerm
What do you mean by surface setting?
Regards,
Vinerm
Old   May 16, 2020, 06:35
Syahirah Jaafar
I have simulated other cases which has the same mesh as the one I've shown before and it would be time-consuming to create new isosurfaces for each one of them. Is it possible for me to duplicate the iso-surfaces that I have done in one case to other cases?
Old   May 16, 2020, 07:37
Default Surfaces
vinerm's Avatar
Vinerm
There are two ways - one is via bc file and other is via journal. Via bc file you don't copy just the surface but whole of the setup. So, if you don't want that then use journal. Journal is not copying from once case to another, rather setting up a journal to create surfaces and report data that you can use with all the cases. Journal commands are text user interface commands.
Regards,
Vinerm
data, fluent, result, solution, tabulation
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
FLUENT Results and Data Tabulation syahirahjaafar FLUENT 0 May 14, 2020 13:40
[General] Make streamlines from Fluent data Gian Maria ParaView 1 January 3, 2013 04:05
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 02:30
how to compare unsteady state problem results from FLUENT with Experimental data? cuddaloreselvam FLUENT 0 July 10, 2011 08:25
