I have problem in expression in specified shear of boundary condition
Like Tree3Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   May 15, 2020, 07:13
Default I have problem in expression in specified shear of boundary condition
kim jihyun
mooving is on a distinguished road
hello
i'm doing graduation project
but i got a problem
when i try to input the formula
sheart stress = dynamic viscosity * dvelocity/dy
on the expression of boundary condition,
the message on the image keeps coming up.
i also attach the image,
please answer the question~
mooving is offline   Reply With Quote
Old   May 15, 2020, 07:20
Default Scalar and Vector
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You are trying to use an expression that returns a vector for a field that is a scalar. Since you are providing value for the component, expression should return a component and not the whole vector.
mooving likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 15, 2020, 08:56
Default how can i make it scalar?
kim jihyun
thank you very much for the answer
but i still have the problem
I also thought the same way and i tried to make it absolute value
but another message comes up.
i guess dVelocitydy is the vector
i attach the image...
Old   May 15, 2020, 09:02
Default Vector
vinerm's Avatar
Vinerm
Yes, dvelocity/dy is a vector because velocity is a vector. You have to use velocity component, say, xvelocity or velocity-x, whichever is correct format.
mooving likes this.
Regards,
Vinerm
Old   May 15, 2020, 09:56
Default thank you
kim jihyun
thank you for the answer
but i don't know if i can change the component
i can only select the component of pascal
i will try to find if i have another measure to solve it.
one more question though,
is it right that if specified shear is zero wall doesn't affect the velocity of fluid?
Old   May 15, 2020, 10:01
Default Clarity
vinerm's Avatar
Vinerm
Your query is not very clear to me. Whether you use velocity vector or scalar, result is always in Pa. A value of 0 implies slip boundary condition; it is different from what you are trying to apply now. You should use the condition that is appropriate for your case.
Regards,
Vinerm
Old   May 15, 2020, 10:13
Default what im trying to do
kim jihyun
yes what you're saying is right
once i simulated with zero shear stress on the wall
the streamline seemed like the wall doesn't affect the velocity of the fluid.
in real situation fluid gradually loses its speed.
so i thought it isn't realistic.
so i though shear stress would make it realistic, but putting in the expression, i have problem as the images i attached before.
if result comes to pascal from both vector and scalar, why there's an error?
i can't understand...
Old   May 15, 2020, 10:18
Default Expression
vinerm's Avatar
Vinerm
Why do you want to apply an expression? Just select no-slip condition.
Regards,
Vinerm
Old   May 15, 2020, 10:25
Default no slip condition
kim jihyun
in no silip condition stream line stops right at the wall
but in my project, i'm trying to improve the flow of fluid in smoking booth
so stream line matters..
Old   May 15, 2020, 10:32
Default Wall
vinerm's Avatar
Vinerm
Walls are walls; they are supposed to stop the flow. If you want a slip, then you have to find out how much slip should be there.
mooving likes this.
Regards,
Vinerm
Old   May 15, 2020, 10:56
Default no slip
  #11
kim jihyun
now i think no slip condition is right
i just simulated again with no slip condition
and found out that fluid near the wall doesn't stop.
the simulation that i did the other day stopped all the fluid soonner because every stream line was on the wall almost right after it's come out from the inlet ( the shape was different from now).
thank you
Old   May 15, 2020, 12:56
Default Streamlines
  #12
vinerm's Avatar
Vinerm
Those are not streamlines, but pathlines. And whether those stop due to wall or not depends on number of steps used for pathline calculation. Default is 500. Use higher value, such as, 20000 or higher, until most of the pathlines have reached outlet.
Regards,
Vinerm
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Speed problem of periodic boundary condition imposed on pitching airfoil. TG777 OpenFOAM Running, Solving & CFD 1 March 20, 2020 16:33
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Wall Shear in Expression as boundary condition w.andreao CFX 2 May 11, 2016 19:53
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
