May 24, 2020, 00:14 |
2-D phase change heat transfer UDF
Arun raj.S
Rep Power: 14 |
Hello everyone, I am performing 2-D phase change heat transfer simulation. I would like to compute the inlet velocity as a function of mass flux and density. The mass flux needs to be computed over each cell in the inlet edge and integrated to get the overall mass flux. Also, the density of the fluid must be corresponding to the fluid in the zone. For example, if it is liquid inlet, it needs to be liquid density. And if it is vapor inlet, it needs to be vapor density. I have prepared this UDF and it works fine. Could anyone confirm if my UDF is right or wrong? It could be help for others too.
#include "udf.h" DEFINE_PROFILE(velocity_inlet, t, i) { real A[ND_ND]; face_t f; Thread *tf; begin_f_loop(f, t) { F_PROFILE(f, t, i) = F_FLUX(f,tf) / (F_AREA(A,f,t)*F_R(f,tf)); } end_f_loop(f, t); } |
May 25, 2020, 12:21 |
Udf
If it works then it's good. But I doubt it. You are trying to apply a profile UDF to an inlet where no values are assigned. If you do not specify either velocity or mass flow rate, how do you expect Fluent to determine the velocity. So, the UDF will compile alright but will not lead to any results.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
How to deal latent heat during phase change through source term udf | dkb_bg | Fluent UDF and Scheme Programming | 4 | April 12, 2018 20:26 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
