Fan Volume Flow Rate
Old   May 29, 2020, 10:56
Default Fan Volume Flow Rate
DL598 is on a distinguished road
Hello to all,
I'm trying to implement the cooler of an electric vehicle into the CFD simulation of said vehicle.
The simulation runs just fine but the Volume Flow Rate through the cooler and fan is way smaller than it should be. (0.02 m3/s with about 0.15 m3/s expected)
I'll attach a screenshot of the settings for the settings of the fan zone and the porous-jump zone.
Does anybody know how I can fix this? I already tried setting the minimum and maximum velocity magnitude on the fan condition. This helped but it still doesn't reach the desired volume flow rate without increasing the velocity magnitude to way more than the fan is capable of.
I calculated the polynomials with my own data according to this tutorial: https://www.youtube.com/watch?v=LUW0yhY8jj0
Also a side note I'm not sure about the Tangential and Radial Velocity Profile as I couldn't find any manufacturer data on this for the fan or find any resources on how to calculate this. For the tangential velocity I simply calculated the velocity of the wingtips of the fan and guessed the radial velocity. Are these values realistic? The fan used is an EBM-Papst 4114 N/2H8P.
Thanks in advance for the help!
DL598 is offline   Reply With Quote
ansys, fan, fluent, porous, radiator
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
volume flow rate for outlet boundry condition and dfine udf for it raminostadi FLUENT 0 December 24, 2016 01:52
two fluid, volumetric/mass flow rate at different volume fractions Veronique Pe CFX 2 November 26, 2014 05:30
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
