Meshing assistance for turbulent flow over flat plate
Old   May 28, 2020, 02:31
Default Meshing assistance for turbulent flow over flat plate
Righardt Ehlers
Ricardo_13 is on a distinguished road
I am trying to analyze the drag coefficient of flow over an inclined (60 deg) flat plate.
At this stage I am only looking at a 2D case
I have looked at various meshing approaches but none seem to give good convergence. I am considering a head on free stream velocity of 15m/s. First layer boundary over plate in the order of 0.25mm.
I have performed structured mesh (taking lead from airfoil examples) as well as unstructured mesh with inflation layers on the surface. An example of the structured mesh approach is in the link. https://ibb.co/30SZJ83
Any recommendation on general approach for this typical problem statement? I am fairly new to CFD.
Ricardo_13 is offline   Reply With Quote
Old   May 28, 2020, 03:06
Default Meshing
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The mesh resolution needs to be observed in terms of y^+. With a baseline mesh that you have generated, run one simulation and then plot the contours of Wall yplus available under Turbulence category on the wall representing the plate. You have to ensure that this value is less than 5 everywhere on the plate. If it is not, refine the mesh accordingly, using a linear multiple, i.e., if you observe that Wall yplus is 50 with 0.25 mm first cell size then you need to use 0.025 mm so that yplus becomes 5.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Finding Drag Force from Skin Friction Rob Wilk Main CFD Forum 0 May 8, 2020 06:04
[ICEM] Meshing of a Flat perforated plate (Zero thickness) hammer ANSYS Meshing & Geometry 6 December 23, 2015 09:54
Validating OF, turbulent flow over flat plate Thilo OpenFOAM Verification & Validation 0 July 3, 2012 05:29
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 21:09
meshing over a flat plate bhanu kishan Main CFD Forum 1 February 7, 2009 14:45
