Difference between using kinetic theory and UDF for mixture mass diffusivity
Old   July 9, 2020, 00:08
Default Difference between using kinetic theory and UDF for mixture mass diffusivity
Yije
yijecho is on a distinguished road
I have an udf code for the mass diffusivity of a mixture, which is based on the kinetic theory of Chapman. The horizontal flow goes through a channel, which has an attached porous zone on the top. There are four species in my model.
When I used the kinetic theory option for mass diffusivity, there is a species concentration difference between the porous zone and channel because of the viscous resistance of the porous zone. However, when I used the udf code, there is no difference between the two zones.
What would be the reason for this?
Thank you,
Yije
https://drive.google.com/file/d/1har...ew?usp=sharing
https://drive.google.com/file/d/1m7e...ew?usp=sharing
yijecho is offline   Reply With Quote
kinetic theory, mass diffusivity, mixture, udf
UDF Macro for Mass Diffusivity using Kinetic Theory souza.emer Fluent UDF and Scheme Programming 5 May 28, 2019 14:28
Multiphase mass transfer udf deada Fluent UDF and Scheme Programming 2 March 27, 2017 08:17
udf for cohesive forces in kinetic theory T.Hari FLUENT 1 October 6, 2014 14:41
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 10:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
