Restarting an unsteady simulation on a supercomputer
Like Tree2Likes
  • 2 Post By averis007
Old   October 16, 2020, 07:21
Default Restarting an unsteady simulation on a supercomputer
Avijeet
averis007 is on a distinguished road
I've been running steady fluent jobs on a supercomputer for sometime now without any hassles. I use journal files for this purpose.
If my case is named as 'example.cas', the journal file commands I use to restart, run 10000 iterations and write files are like this:
rcd example.cas
solve/iterate 10000
wcd outfile.cas
Now, for unsteady simulations, I've been able to start new cases and run unsteady simulations using the following commands:
rc example.cas
/solve/initialize/compute-defaults/pressure-far-field farfield
solve/iterate 10
solve/dual-time-iterate 50 10000
What this does is basically initialize with farfield conditions and then run 50 time steps with 10000 iterations each.
The problem I'm facing is that I want to run a further 20 more timesteps. But I've been unsuccessful in doing so. I tried running with the following commands in the journal file:
rcd example.cas
solve/iterate 10
solve/dual-time-iterate 20 10000
But it failed to run because fluent is looking for the file example.dat whereas the solution files for different time steps are numbered as example-00001.dat, example-00002.dat ..... upto example-00050.dat.
If someone can help me in finding the appropriate command to make fluent understand that this is an unsteady case and I want it read the data from time step number 50, that'll really help me out. thanks in advance.
mcuneytk and Vasanth Kumar G like this.
averis007 is offline   Reply With Quote
Old   March 31, 2021, 09:16
cuneyt
mcuneytk is on a distinguished road
Hi, did you find any solution to ur problem ?
Thx.
mcuneytk is offline   Reply With Quote
fluent - parallel, journal files, restart solution, supercomputer, unsteady
Add a stop criteria for an unsteady multiphase simulation Jeneas OpenFOAM Pre-Processing 0 May 18, 2018 09:22
SU2 unsteady simulation Gaetano03 SU2 2 November 29, 2017 11:06
How to Run Unsteady Simulation in Star CCM+? Andi_Didi STAR-CCM+ 4 November 13, 2017 01:41
Current number and time step for an implicit unsteady simulation Clémence STAR-CCM+ 2 September 30, 2016 09:30
Rigid body motion error when restarting a terminated FSI simulation lingdeer ANSYS 1 May 19, 2013 01:40
