heat flux at wall vs adiabatic vs constant temperature |
March 17, 2021, 10:18 |
Hello CFD enthusiasts,
I have an observation rather than question. Please correct me if I am worng. If I apply one of the following conditions at a WALL type surface 1. Heat flux at wall 2. Adiabatic wall 3. Constant wall temperature The heat flux would be 1. same as given 2. zero 3. some value depending on flow above. Is this my concept correct? One of my friend wants heat flux at wall while I said that i can give only temperature due to second BC (i.e adiabatic wall) condition has been applied. Thanks and regards, SJ |
March 17, 2021, 23:55 |
Lucky
Rep Power: 66 |
1. Yes. 2. Yes. 3. Yes.
That said, if your friend wants to apply a heat flux, why are you doing 2, insisting that only 3 can be done (even though you are doing 2), and not doing 1? |
March 18, 2021, 08:07 |
Thanks, Lucky, I think you did not get my last point. I said that when friend asked me to give heat flux, I refused because I said I cant give you heat flux since the wall is adiabatic. I can only show you temperature at the wall.
Wall Temperature dependence on Y+ for constant heat flux bc | arvindpj | Main CFD Forum | 5 | September 12, 2022 12:37 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
bulk mean temperature 2D flow constant heat flux at one wall | shan2baba | FLUENT | 0 | January 9, 2015 03:44 |
Constant heat flux with uniform temperature | Jake Lee | FLUENT | 2 | April 13, 2011 22:08 |
