April 13, 2021, 06:27 |
First cell-height for aircraft Simulation
Rep Power: 10 |
I am trying do a simulation of a small aircraft in order to estimate the drag coefficient. 1.: In order to reduce the number of cells, I want to use standard wall function. So I am trying to set y+ between 30 and 300. My question: which reference length should I use in order to calculate the first cell height? a) When I use the chord length of the airfoil as reference length I will need a smaller first cell height than using the fuselage as reference length. In order to be sure that y+>30 I should then go for the fuselage first cell height? b) And what is my free stream velocity? The wing is accelerating the incoming air. So when I set to my farfield boundary Mach=0.7 , is this my free stream velocity (for calculating first cell height) or should I approximate the velocity on the airfoil and use this as free stream velocity (around Mach=0.9) ? 2. Do you think it is important to NOT work with wall functions for solving for drag coefficient of an aircraft (with high angle rudders) ? Thanks for your thoughts Best regards CellZone |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Need an array with cell height values | Mira | OpenFOAM Programming & Development | 1 | July 16, 2019 05:32 |
How to calculate First Cell Height For Laminar Flow ? | vinayak4399 | Main CFD Forum | 2 | July 17, 2015 03:24 |
[GAMBIT] optimum first cell height value for flow within a air turbine | aja1345 | ANSYS Meshing & Geometry | 6 | May 27, 2015 07:30 |
[ICEM] first cell height for laminar flow | GrN | ANSYS Meshing & Geometry | 1 | May 21, 2015 13:12 |
