How to write the journal file for the two-phase solver on cluster? |
July 17, 2021, 09:48 |
Rep Power: 6 |
Dear,
I am a new user to fluent. Recently, I have met a problem. I want to use fluent on cluster to model two-phase flow. Thus, I have to write the command lines in a journal file to initialize the simulation. I know the regular command lines. But I have no idea writing the command line for multiphase solver. Especially how to patch a region and initialize the region. I will appreciate it if someone could give me an example or hint. Thanks a lot |
July 19, 2021, 21:24 |
Alexander
Rep Power: 34 |
to do it you need TUI commands and scheme
you may check TUI commands in fluent console click in console and press enter, you will see the list of available options, for example Code:
adapt/ file/ report/ define/ mesh/ solve/ display/ parallel/ surface/ exit plot/ views/ you may initialize and patch using something like this Code:
(ti-menu-load-string (format #f "solve initialize initialize-flow OK")) (ti-menu-load-string (format #f "solve patch mixture zone-1 zone-2 () temperature no 300")) (ti-menu-load-string (format #f "solve patch mixture zone-1 zone-2 () temperature no 400"))
best regards ****************************** press LIKE if this message was helpful |
July 21, 2021, 00:05 |
Rep Power: 6 |
thanks a lot. AlexanderZ, I will try your method as soon as possiple
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
