Why my calculation of Mach number is not the same as fluent |
August 30, 2021, 09:24 |
iiran
Rep Power: 4 |
Hello, everyone. I have a problem when I want to verify my inlet data on the supersonic fluid.
I use the equation “Mach number = Velocity / (1.4 * R * static temperature)”, and what amazing me is that when I substitute the following data into the equation, I find the Mach number is 2.4970 (R is 287.15 for air), but fluent shows that the mach number is 2.439456. So I wonder why this happens and how to get the real answer as fluent? Thank you in advance! |
August 30, 2021, 09:50 |
iiran
Rep Power: 4 |
Now I understand why , this because it uses the average number, I don't know how to delete this post, thank you for you reading.
supersonic flow, supersonic inlet |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
