hydrogen jet into calm air
Like Tree1Likes
  • 1 Post By LoGaL
Old   October 19, 2021, 06:06
Default hydrogen jet into calm air
Giuseppe
pulplus is on a distinguished road
Hi!
I need to model a hydrogen jet into a chamber with calm air. So basically it should be a gas-gas interaction, and, as I read from the manual, multiphase models can't be used for gas-gas problems. So how can I do it? Is there any tutorial? Moreover, do I have to create two separate zones for the nozzle from which the hydrogen comes in and for the ambient containing air?
Please help!
pulplus is offline   Reply With Quote
Old   October 19, 2021, 11:30
Lorenzo Galieti
LoGaL is on a distinguished road
Hi, if the hydrogen is gaseous, you can model it with species transport, which is much easier than multiphase flow. You should understand why hydrogen and air (which by the way is in turn nitrogen mixed with oxygen ) in gas form can be considered a single phase . It has something to do with miscibility
pulplus likes this.
LoGaL is offline   Reply With Quote
Old   October 19, 2021, 12:35
Giuseppe
Thanks for your answer, I suspected it can be considered a species transport problem. Anyway, do you have any tutorial to suggest? I don't know how to set the simulation from the design modeler to fluent. Do I have to set two 2D bodies, one for the nozzle and one for the ambient with calm air? Moreover, how can I tell fluent that the air in the ambient is calm?
Thank you!
Old   October 21, 2021, 22:21
iiran
ranxiaoran is on a distinguished road
Thank you!
Anyway, I think searching the combustion case in the youtube can be helpful for you
ranxiaoran is offline   Reply With Quote
air, ambient, hydrogen, jet
Air entrainment model setup for spillway oajor FLOW-3D 4 November 17, 2016 12:02
Argon jet into Air : which solver should I use ? eddadagow OpenFOAM Running, Solving & CFD 1 December 4, 2012 04:10
Water jet in confined hot air cross flow Jim Clancy FLUENT 0 November 24, 2007 16:14
Air jet simualation Yue Zou Main CFD Forum 8 February 15, 1999 12:19
air jet simulation Yue zou Main CFD Forum 0 September 28, 1998 08:30
