Disable Equations in one Domain only
Old   March 1, 2022, 04:26
Default Disable Equations in one Domain only
Baum is on a distinguished road
Hello guys,
I was wondering today whether it is possible to freeze certain equations (or all equations) in a certain part of my simulation. For example, I know that the flow at the inlet is relatively constant throughout my simulation, so calculating the transport equations in that region every iteration is just a waste of computing time. I separated the regions, but I don't know whether it is possible to disable the equations in that region alone.
I could of course separate it into a different mesh and interpolate the boundary values, but that would take some more work, which I was hoping to avoid.
Thanks!
Baum is offline   Reply With Quote
Can CFX model periodic heat transfer problem Ethan_Sparkle CFX 41 June 14, 2017 07:22
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 04:07
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
