May 1, 2022, 16:05 |
Exporting velocity field
Behnam Kazemi Majd
Rep Power: 3 |
Hello dear friends
i am trying to export a velocity field obtained from a 3D simulation in a format that i can process the data in MATLAB software. What i need is a three-dimensional matrix containing u,v,w in x,y,z directions for each node. For instance: U(x,y,z) V(x,y,z) W(x,y,z) in 2D it will be something like this, there will be 3 matrices for u v and w U(x,y) V(x,y) W(x,y) has anyone ever done this before? thanks |
May 1, 2022, 16:30 |
Lucky
Rep Power: 66 |
File export solution data. Use ascii.
Then use the data reader utility in malab or the delimited text reader. |
May 3, 2022, 00:46 |
Behnam Kazemi Majd
Rep Power: 3 |
Thank you so much, i tried it and i could sort the data as i desired !
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 13:38 |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 08:34 |
Finely dispersed particles in predetermined velocity field | BrainDebugger | STAR-CCM+ | 1 | May 14, 2014 06:32 |
velocity of massless particles and velocity of flow field in same coordinate | payam_IUST | FLUENT | 0 | October 18, 2009 23:24 |
