[DPM/DDPM]How to employ UDF only for total flow rate of a injection?
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   June 26, 2016, 10:19
Smile [DPM/DDPM]How to employ UDF only for total flow rate of a injection?
Narita is on a distinguished road
Dear all,
My simulation is transient, and I have tried DEFINE_DPM_INJECTION_INIT and 'loop(p,I->p_init)' inside for a simple constant-flow-rate case. However, the tracked particle number didn't increase with time.
In this situation, I start to think about writing an UDF which only modifies the total flow rate of a injection. I believed I could do it since we have a dropdown right beside the total-flow-rate blank.
Unfortunately, I failed to find the way to do it although I thought I've well read through the UDF guide..
Does anyone has some good ideas?
Narita is offline   Reply With Quote
Old   June 27, 2016, 01:18
Exclamation
Originally Posted by Narita View Post
Dear all,
It seems I made a mistake when employing DEFINE_DPM_INJECTION_INIT. I'm now attempting with it.
Back soon for any news!
Old   June 27, 2016, 01:25
Exclamation
Sorry I made a mistake in my codes.
The good news is that you can freely use the macro to set the injection flow rate as a function as you like -- it perfectly works with the transient DPM simulation.
Old   May 2, 2022, 11:17
Smile ask for help
ala_liar is on a distinguished road
Hello Narita,recently I'm having the same problem you used to have. Here's my code:
DEFINE_DPM_INJECTION_INIT(fuel,I)
Particle *pt;
real time = RP_Get_Real("flow-time");
real m1=0.012667, m2=0.014057;
loop(p,I->p_init)
PP_FLOW_RATE(p) = (fuel_m1+(fuel_m2-fuel_m1)*time/0.6)/12;
When I intepret it, here's error:"reference not implemented",
when I compile it, erro:"not for parallel“
Now I wonder whether my code is right but not for parallel, or I got something wrong? Can you show me the way you solve it ? I'd appreciate your help!
ala_liar is offline   Reply With Quote
Old   May 3, 2022, 00:41
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
the only part which could be a problem for parallel consideration is this line:
change to
real time = CURRENT_TIME;
ZZH1997 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
injection, total flow rate
Particle Injection Flow Rate [kg/m2-s] Manathan FLUENT 2 May 5, 2015 03:09
mass flow rate... sanjar OpenFOAM Running, Solving & CFD 1 December 2, 2013 00:09
mass flow rate inlet udf alikami Fluent UDF and Scheme Programming 3 June 4, 2010 13:47
UDF mass flow rate Juan FLUENT 2 December 22, 2007 09:29
How to calculate the mass flow rate with UDF ? HP FLUENT 0 January 10, 2005 19:38
