floating point exception
Old   June 29, 2022, 00:07
Default floating point exception
Karthik
Karthik_1788 is on a distinguished road
Hi all, while doing CFD I got this error in fluent
can anyone tell the reason and alternative.
I want to simulate pcm setup which contains refrigerant, copper coil and water.
kindly help
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: #f
Karthik_1788 is offline   Reply With Quote
Old   June 29, 2022, 12:08
Mars35 is on a distinguished road
Hi, I am not sure if my case has the exact same error as yours. (it also showed floating point error) But I fixed it by correcting my flow direction. You can double-check that.
Mars35 is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 11:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 09:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 04:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 13:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 19:28
