August 10, 2022, 16:47 |
Attempting to add 'imaginary' heating
Rep Power: 3 |
I am attempting to add heating into my CFD model. The heating in the real world is done by induction by using an RF generator. As I do not know how to model this and to simplify the model, I am trying to create a volume within a larger volume, the smaller of which needs to heat up. Is this sort of "imaginary/fake" heating possible? If not, how may I model something like this? Thank you in advance |
August 10, 2022, 17:30 |
Lucky
Rep Power: 66 |
A volumetric heating source is a very reasonable approach and assuming you can specify the equivalent volumetric heating rate in power per volume corresponding to the amount of heating provided by induction, the volumetric heating approach allows you model everything within the scope of ohmic heating. And ohmic heating covers pretty much all of induction-based heating up to the limit of there being evanescent waves.
Just check the volumetric heating box and then it's just a matter of giving a reasonable number or a reasonable field of values to apply the heat. |
August 10, 2022, 17:41 |
Volumetric heating box location
#3 | |
Rep Power: 3 |
Thank you again in advance! |
August 10, 2022, 17:44 |
Lucky
Rep Power: 66 |
If you are doing it the sensible way and modeling heat conduction in a solid then it is in cell zone conditions, and there is a check box for source terms.
August 10, 2022, 17:48 |
Rep Power: 3 |
Perfect, thank you very much! I really appreciate the help
cfd aerospace, fluent, heating |
Simulation Explodes when I add surface Layers | Phill_G | OpenFOAM Running, Solving & CFD | 2 | May 23, 2022 14:44 |
[PyFoam] and paraview | eelcovv | OpenFOAM Community Contributions | 28 | May 30, 2016 09:23 |
Heating value of fuel in non-premixed model? | Jeronimo97 | FLUENT | 0 | February 15, 2013 14:27 |
Pressure variation in a heating channel | gRomK13 | Main CFD Forum | 0 | August 6, 2009 12:18 |
Add Measure Markings or Coordinates to the Contour | Colin | FLUENT | 4 | August 25, 2004 09:54 |
