March 12, 2023, 13:42 |
Coarsening / dynamic mesh
Aemon alCaar
in a simulation, I work with a dynamic mesh. Unfortunately, the number of cells increases over time (possibly also by improving the mesh quality, which also consistently worsens). I have tried to combine small cells via mesh adoption, but apparently still have a thinking error. If I set as Coarsening Criterion. - CellVolume<1e-10[m]^3, 0 cells are marked. If I enter - CellVolume>1e-10[m]^3, also 0 cells are marked. If, on the other hand, I specify for Refinement Criterion - CellVolume>1e-10[m]^3, 2960485 cells are marked (all). Perform MeshCheck says: Volume statistics: minimum volume (m3): 3.370395e-12 maximum volume (m3): 2.538826e-04 Can someone explain me the behavior or tell me what I can do so that I can combine small cells? Thanks a lot Aemon |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 04:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
