Why temperature is decreased shaply when calculation is started?? |
June 16, 2023, 05:16 |
kim
Rep Power: 2 |
Hello all, plate air cooling is the topic
I made 6points on the surface of plate to plot the temperature along the time. After starting calcuation temperature of vertex is dropped sharply and increase slowly. I think it is not physcal for cooling. usually temperature will be decreased very slowly for air cooling. initial temp for plate is 780℃ , ambient air temp is 20℃ there is plot snap below please advise something. thanks |
June 20, 2023, 07:17 |
Laurens
Rep Power: 7 |
Hi Hackis,
I need some more information on the problem setup. What did you do? Did you solve the flow field before patching the plate with a temperature? Did you mesh the boundary layer correctly? This is a common case in textbooks, did you determine a Biot-number? If heat transfer coefficient is large, you might need an inflation layer within the plate as well. |
June 21, 2023, 13:15 |
here are what i did
#3 | |
kim
Rep Power: 2 |
first of all thank you for your respond here are what i did befor solving this model 1. befor patching the plate with a temperature, i initialized thr flow field as 293K, -1.5m/s 2. there are two domains(solid=steel, fluid=air) 3. one interface with two domains, so i selected coupled thermal boundary 4. i didn't determine a Biot-number, heat transfer coefficient because there is no option specify a Bi or HTC (if it is possible please give me some advise) 5. instead of that i specified thermal properties of air and solid, because convection and conduction are influenced by material properties, flow characterics of fluid. (specific heat, thermal conductivity, heat diffusivity, heat expansion coeff, density) 6. i meshed hexagonal for solid and trigonal for fluid the worst EquiSize Skew : 0.896 Orthogonal Quality : 0.103 does this mesh could be problem? i attatch plane view of mesh for solid and fluid field 7. heat transfer coefficient is 35.5467 W/㎡*K avg. (computed value) 8. also i found the fact that plot using total temperature for wall shadow(solid) was started from inital temperature(1063K), not static temperature. is it right physically?? i attatch the plot. thanks again think about the problem together, i wish solve this plz. |
June 22, 2023, 04:26 |
marwane cherkaoui
Rep Power: 2 |
Hello,I think you don't have a good mesh quality (orthogonal quality: 0.103 is low), and will give errors in the results. In my opinion, you need to alter the mesh size.
June 22, 2023, 16:04 |
thanks for respond
#5 | |
kim
Rep Power: 2 |
thank you for your opinion, and i try to mesh again for better quality. i attach another plot that comparing total & static temp plot along for each wall(fluid interface) and shadow wall(solid interface). |
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 11:16 |
Calculation of Physiological Equivalent Temperature Index using UDF | shadymody | Fluent UDF and Scheme Programming | 1 | January 8, 2023 14:37 |
Changing the temperature calculation from Energy Equation | godfatherBond | OpenFOAM Programming & Development | 3 | October 16, 2017 00:42 |
Porous Media initial temperature calculation and definition | misterdd | FLUENT | 3 | December 16, 2013 12:48 |
Boiling temperature calculation | femer | STAR-CCM+ | 0 | March 31, 2013 21:15 |
