August 29, 2023, 13:03 |
Conjugate heat transfer
Jacob
Rep Power: 8 |
Hello everyone,
I was going through the Fluent documentation and this forum but I couldn't find out a solution to my problem. I wanted to model a heat exchanger where one fluid transports heat to the other fluid where both are separated by a solid region. I created a mesh and everything. Eventuallly, I have mesh interfaces where I selected coupled for the fluid and solid zones, respectively. I also got a solution, but one thing that worries me is that in wall boundary conditions I have like: contact_region_10_wall1-1-1(wall, id=229) contact_region_10_wall1-1-1-shadow(wall, id=232) wall_1_fluid-contact-region_10-src-non-overlapping(wall, id=230) wall_1_solid-contact-region_10-trg-non-overlapping(wall, id=231) And those last two walls were created after I set coupled in mesh interfaces. I am not sure if I should have so many walls that seem to refer to one thing Moreover, In the first two walls, I have coupled option marked. But in the last two, I still can choose wall boundary conditions. I also tried setting different values of heat transfer coef, or free stream temp., but it turned out it did not affect the solution. Any advice would be helpful |
September 6, 2023, 04:37 |
Moritz Kuhn
The last two walls are not coupled together. You have to check your geometry, that these is only one face or use the mapped option in fluent to couple these non-overlapping walls.
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Conjugate Heat Transfer In Porous Media | gartz89 | FLUENT | 3 | February 7, 2023 02:24 |
Cyclic conjugate heat transfer | johanesp | OpenFOAM Programming & Development | 0 | December 30, 2021 10:55 |
No conjugate heat transfer between solid (cast iron) and fluid (water) | Rajaero | Main CFD Forum | 1 | August 23, 2018 13:01 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
