How do I apply a sliding mesh on a sector shape? |
November 23, 2023, 08:35 |
sunny
Rep Power: 3 |
hello.
I applied a sliding mesh model with fluent and I have a problem. The simulation is a sector shape as shown in the picture. The inside and outside are fixed areas, and the gradient part is the area that rotates by applying mesh motion. When I ran the simulation, I got the same result as the first time, but I also set the mesh interface, so I thought it was okay as long as I could see the interaction between the two meshes, so I continued to run the simulation. However, when I checked the results afterwards, I couldn't see the interaction between the two meshes because the mismatched meshes were applied as a wall. Therefore, I think I need to set it to rotate like the second one, is there any way to do that? Thank you. |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
Overlap and gap between cell zone for sliding mesh | cs12345 | FLUENT | 2 | December 14, 2017 08:41 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Sliding Mesh | Sridhar | FLUENT | 0 | August 23, 2002 14:54 |
