February 14, 2024, 04:31 |
PyFluent Parametric Command
Youwann
I'm trying to use PyFluent to modify a already existing case : Code:
%matplotlib import ansys.fluent.core as pyfluent solver = pyfluent.launch_fluent( precision="double", version="2d", processor_count=10, mode="solver", show_gui='True' ) solver.file.read(file_type="case", file_name="example.cas.h5") solver.tui.define.boundary_conditions.list_zones inle = solver.setup.boundary_conditions.mass_flow_inlet['inlet'] inlet.mass_flow = 0.01 solver.file.write( file_type="case", file_name="example.cas.h5", ) solver.tui.define.parameters.enable_in_TUI("yes") Code:
solver.tui.define.parameters.input_parameters.advance.use_in("udf_size", "htc_ext", 20) Code:
invalid command [udf_size] Error: wta(2nd) to string_eq Error Object: #f Code:
define parameters input-parameters advance use-in udf-side htc_ext set 0 Code:
Error: eval: unbound variable Error: 'htc_ext'is predefined expression. Please change name. Error Object: #f |
February 15, 2024, 03:02 |
Update
Youwann
I found the command for Python:
solver.tui.define.parameters.input_parameters.edit("name", "new_name", value) |
EnSight - queue of command files and abaqus post-processing | Delcraft | EnSight | 1 | June 1, 2016 16:38 |
invalid command error | Hashir Shafi | Main CFD Forum | 1 | April 8, 2016 03:32 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Command Line vs. GUI Menus | Go | FLUENT | 0 | June 8, 2005 16:05 |
