PyFluent Parametric Command
Like Tree1Likes
  • 1 Post By Youwann
Old   February 14, 2024, 04:31
Default PyFluent Parametric Command
Youwann
Youwann is on a distinguished road
I'm trying to use PyFluent to modify a already existing case :
%matplotlib
import ansys.fluent.core as pyfluent
solver = pyfluent.launch_fluent(
    precision="double",
    version="2d",
    processor_count=10,
    mode="solver",
    show_gui='True'
solver.file.read(file_type="case", file_name="example.cas.h5")
solver.tui.define.boundary_conditions.list_zones
inle = solver.setup.boundary_conditions.mass_flow_inlet['inlet']
inlet.mass_flow = 0.01
solver.file.write(
    file_type="case",
    file_name="example.cas.h5",
solver.tui.define.parameters.enable_in_TUI("yes")
But when I try to change an input parameter :
solver.tui.define.parameters.input_parameters.advance.use_in("udf_size", "htc_ext", 20)
I obtain :
invalid command [udf_size]
Error: wta(2nd) to string_eq
Error Object: #f
and why I try to use the TUI commande :
define parameters input-parameters advance use-in udf-side htc_ext set 0
It didn't work either :
Error: eval: unbound variable
Error: 'htc_ext'is predefined expression. Please change name.
Error Object: #f
Is there a way to run TUI code directly in a jupyter notebook or a command to update existing Pyfluent parameters?
Youwann is offline   Reply With Quote
Old   February 15, 2024, 03:02
Default Update
Youwann
I found the command for Python:
solver.tui.define.parameters.input_parameters.edit("name", "new_name", value)
Volcano Nebula likes this.
EnSight - queue of command files and abaqus post-processing Delcraft EnSight 1 June 1, 2016 16:38
invalid command error Hashir Shafi Main CFD Forum 1 April 8, 2016 03:32
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Command Line vs. GUI Menus Go FLUENT 0 June 8, 2005 16:05
