floating point
Old   March 3, 2024, 22:42
Default floating point
nancy frias
1183480 is on a distinguished road
Hello!
I have a multiphase simulation with an energy model and a moving mesh.
this error occurs only when i activate the energy model, because the eulerian solver and the moving mesh works fine.
I have tried this:
1. improve the quality of the mesh
2. lower the time step
thank you for your comments
Reversed flow on 148 faces of pressure-outlet 14.
Reversed flow on 4 faces of pressure-outlet 15.
Reversed flow on 49 faces of pressure-outlet 14.
Reversed flow on 7 faces of pressure-outlet 15.
Stabilizing mp-x-momentum to enhance linear solver robustness.
Stabilizing mp-x-momentum using GMRES to enhance linear solver robustness.
Stabilizing mp-y-momentum to enhance linear solver robustness.
Stabilizing mp-y-momentum using GMRES to enhance linear solver robustness.
Stabilizing mp-z-momentum to enhance linear solver robustness.
Stabilizing mp-z-momentum using GMRES to enhance linear solver robustness.
Stabilizing temperature to enhance linear solver robustness.
Stabilizing temperature using GMRES to enhance linear solver robustness.
temperature limited to 1.000000e+00 in 290633 cells on zone 7 in domain 2
temperature limited to 1.000000e+00 in 290633 cells on zone 7 in domain 3
temperature limited to 1.000000e+00 in 28292 cells on zone 8 in domain 2
temperature limited to 1.000000e+00 in 28292 cells on zone 8 in domain 3
temperature limited to 1.000000e+00 in 28157 cells on zone 9 in domain 2
temperature limited to 1.000000e+00 in 28157 cells on zone 9 in domain 3
Stabilizing vof-1 to enhance linear solver robustness.
Stabilizing vof-1 using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: vof-1
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 346183 cells
Error at Node 0: floating point exception
Error at host: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error: floating point exception
Error Object: #f
I have looked at some of the suggestions that data very out of touch with reality can give this error.
I guess it could be the way I set up my materials as there are 3 of them and in some properties I use polynomial and in others constant but it is not the same for any of the materials.
Last edited by 1183480; March 3, 2024 at 22:47. Reason: more information about the problem
1183480 is offline   Reply With Quote
Old   March 4, 2024, 15:03
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
This is likely from how you defined you material properties. I have seen it in the past that when the properties are defined incorrectly you will get these computational errors across many equations.
For the polynomial equations, make sure you have enough significant figures for each coefficient (at least 6+ significant figures). For all materials make sure you have defined the material properties through the entire range of expected temperatures or other variables. If the property goes outside the range provided it may default to 0 causing numerous errors in the solver. Finally, make sure your units are correct for each material property. Datasheets can often use different units than Fluent.
Also, double check how you are defining the thermal boundary conditions. Incorrect units can lead to multiple orders of magnitude difference in the thermal boundaries. Finally, check how you are initializing the domain and make sure all your boundaries and VOF phases are being intialized correctly.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Understanding The Floating Point Exception Error Message RussellHolt OpenFOAM Running, Solving & CFD 2 August 6, 2022 01:00
InterFoam based solver running into floating point error on restarting simulation Venky_94 OpenFOAM Running, Solving & CFD 9 November 23, 2021 17:53
Floating Point Exception - Mesh Related?? edomalley1 OpenFOAM Running, Solving & CFD 2 November 8, 2018 12:30
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
