Grid-checking issue in Fluent
Old   November 30, 1999, 11:01
Default Grid-checking issue in Fluent
Vince
When checking my 2D grid under Fluent 5, I get the following message : "Warning ! Non positive face area exists."
My minimum face area equals zero.
The grid seems ok, since no nodes are redundant. I really can't understand why a face area is detcted.
Any idea ? Thanx in advance.
vince
Old   December 2, 1999, 21:55
Default Re: Grid-checking issue in Fluent
Scott Gilmore
Fluent France should be able to help you with this. You may need to send the grid file to them.
Old   December 3, 1999, 09:15
Jonas Larsson
You probably have a collapsed cell somewhere in your grid. I suggest that you bring it back to the pre-processor and check the quality of it.
Old   December 4, 1999, 21:56
wang haigang
Hi, I think you should used the Tgrid to check the mesh,it will help you check you mesh. wang haiggang
HELP! grid check failed in parallel fluent restart FLUENT 0 March 5, 2011 09:55
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
LES on unstructured grid in fluent Zafer Zeren FLUENT 0 December 20, 2005 06:45
Problem on building grid operation (fluent) remy FLUENT 0 April 12, 2002 10:37
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 12:35
