Velocity profiles
Old   May 18, 2001, 07:44
Default Velocity profiles
merac
Hi folks, I'm trying to plot pipe/annulus flow velocity profiles on Excel, comparing my analytical calculations with Fluent's results. I've created a line across the pipe diameter in Fluent, and need to report the velocity at the node values where the line intersects each value. Is there a quick way to do this, short of clicking on every point and noting down the velocity?
Old   May 22, 2001, 15:41
Default Re: Velocity profiles
Lanre
Open the Plot-->XY Plot... panel. Check the "write to file" option. Select the variable of interest and chose the correct orientation vector of your line, select your line from the list of surfaces, click "write". This will prompt you for a file name. Your variable data and corresponding position are written to file that you can view in a text editor or read into Excel.
Old   May 23, 2001, 04:54
merac
Thanks alot!
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
Velocity Profiles Sal FLUENT 3 August 2, 2007 09:06
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
turbulent velocity profiles at cylinder exit shaheeb FLUENT 0 February 7, 2006 18:00
