UDF on-off Pulsed velocity inlet
Old   March 10, 2002, 22:07
Default UDF on-off Pulsed velocity inlet
Samuel
Hi, I've got a problem using UDF for inlet velocity profile.
I have managed to write in Matlab file, but having trouble to write in Fluent UDF file.
**********vinlet.m***********
clear all;
<blockquote>
for I=0:Per:0.5
<blockquote>
for t = I:0.001:I+Per
<blockquote>
if(t<=I+Per/3),
Flow = abs(A*sin(3*pi*t/Per));
else
Flow = 0;
end
plot (t,Flow);
hold on;
</blockquote>
end
</blockquote>
end
</blockquote>
plot (t,Flow);
*****END******
*******vinlet.c***********
#include "udf.h"
DEFINE_PROFILE(inlet_xv_sinusoidal, /* function name */ <blockquote> <blockquote>
<blockquote>
<blockquote>
thread, /* thread */
nv) /* variable number */
</blockquote>
</blockquote> </blockquote> </blockquote>
<blockquote>
face_t f;
real pi = 4*atan(1);
real U = 36.6;
real A = 3*pi*U/2;
real Per = 0.1;
real i;
real flow_time = RP_Get_Real("flow-time");
for (i=0:Per:flow_time) /* NOT sure how to define "for" or is this possible? */
<blockquote>
begin_f_loop (f,thread)
<blockquote>
if (flow_time <= i+Per/3.)
F_PROFILE(f,thread,nv) = fabs(A*sin(0.3*pi*flow_time)); /* What is an equivalent command for "hold on" in Fluent or is this possible?*/
else
F_PROFILE(f,thread,nv) = 0.;
</blockquote>
end_f_loop (f,thread)
</blockquote>
end
*****END********
I am trying to model on-off pulsed jet with 1:2 ratio.
My real question is how to create a loop for the cycles in terms of flow_time. As in the matlab, I just defined this cycle (the fisrt loop, i = 0:0.1:0.5) where 0.5 being a chosen number, as in the FLUENT, it should be defined in "Interate" FLUENT GUI panel as "number of time step".
Is it possible to create a loop for flow_time?
Any inputs will be appreciated!
Thanks
sam
udf parabolic velocity inlet with unsteady case Faruk Beyca FLUENT 4 June 24, 2022 10:45
UDF for Velocity change at inlet haihek FLUENT 7 August 2, 2019 07:45
USED UDF for inlet velocity in 3D sara FLUENT 0 October 11, 2007 18:04
Fluent UDF load and apply inlet velocity b.c. Knut Lehmann Main CFD Forum 2 June 29, 2007 04:53
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
