Fluent data format
Old   April 29, 2002, 10:43
Default Fluent data format
khalil
It appears that the fluent 5.5.14 mesh files are in ASCII file format and the data files are in binary. Is there any way of outputting the data fiel as ASCII? Can fluent 5.5 files be saved as fluent 4.5 files? (i'm prertty sure 4.5 data files are ASCII)
any help would be much appreciated
many thanks khalil
Old   April 29, 2002, 10:48
Default Re: Fluent data format
An Modh Coinniolach
Uncheck the "write as binary" option in the save dialog.
Old   April 29, 2002, 11:05
khalil
If your ever in Manchester, England let me know, i'll buy you a drink!!!!!
thanks
Old   May 1, 2002, 05:26
An Modh Coinniolach
Deal!
Old   May 1, 2002, 05:57
An Modh Coinniolach
If you get brave you can start fiddling with the data values. I guy in the office was looking at using Fluent as a postprocessing tool for his experimental data. You get a different perspective on CFD when you can write your name in the fluid domain.
Reading Additional Data Quantities from Fluent into Tecplot fremder Tecplot 9 December 16, 2016 15:35
NASTRAN Data format Srinivasan Arunajatesan Main CFD Forum 1 January 2, 2014 06:20
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 02:30
[GAMBIT] Fluent 4 GRD format problem and Plot3d format praveen ANSYS Meshing & Geometry 0 June 7, 2010 10:09
Fieldview Data Format?? Choong K. Yoo FieldView 0 August 23, 1999 19:59
