Templates in Fluent
Old   May 3, 2002, 05:53
Default Templates in Fluent
Christian
Hi.
Is it possible to make a template in Fluent, so if I have similar models I can re-use BC's, material data etc.
I know that it is possible to read a dpm file, although you have to make the file first, and then import it (it would be nice if Fluent could make a dpm file from the gui).
Cheers Christian
Old   May 5, 2002, 20:43
Default Re: Templates in Fluent
Jin-Wook LEE
Use 'write-bc' and 'read-bc' from TUI(Text User Interface), not from GUI. Then you can write and read everything in the case file.
Sincerely Jinwook
Old   May 6, 2002, 02:18
Christian
Thank you, Jinwook.
Do you know if it is possible to de the same thing with the materials database. When I use DPM, I have to alter the database, and errors may occur.
Cheers Christian
Old   May 6, 2002, 05:09
Erwin
No, the same command works well for the database as well. Just use write-bc and read-bc as Jin-Wook said.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
