DPM Reversed Flow
Old   June 3, 2002, 12:12
Default DPM Reversed Flow
Hendawi
Hi every one,
I'm modeling a water jet heat&momentum transfert PM. In first step, I'm tying to model the continous phase (like what's done in tutorial 14: Modeling Evaporating Liquid Spray). I take a cubic volume; as BC: 1-a velocity inlet face for gas velocity 2-a pressure-outlet face for atmospheric pressure (the opposite face) 3- the 4 remaining faces (lateral faces) are set as outflow. In this first step of modeling the gasous phase, the model is converged but always with the message " reversed flow in 601 faces on pressure-outlet ". If you have any idea to solve this problem, please tell me.
Thank you in advance.
Old   June 3, 2002, 15:52
Default Re: DPM Reversed Flow
LW
Reversed flow may not be a problem. Based on your model domain shape and flow characteristics, you may have in-flow through the model outlet. Think if it is possible in your real applacation.
regards,
LW
Old   June 5, 2002, 05:01
Jin-Wook LEE
H'mmm. Let me see.......
Your set of boundary condition is mathematically well-posed ?
I am slightly confusing, but I think that 'pressure-outlet' and 'outflow' should not be used at the same time.
Sincerely, Jinwook
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) zhaoyu_001 FLUENT 0 April 7, 2010 00:24
Reversed flow at pressure outlet Seeker Phil FLUENT 9 January 2, 2010 05:21
reversed flow Lakshmi Kanth FLUENT 1 September 26, 2005 00:41
DPM mass flow rate Szabolcs Varga FLUENT 3 May 6, 2004 15:21
reversed flow mukkarum FLUENT 1 April 13, 2004 11:17
