August 1, 2002, 07:37 |
Is it a fluent bug???
hi cfd's can anybody explain this error..
try this Using Report-->volume integral(Epsilon) get volume weighted averaged epsilon. After that using Define-->Caustom field functions--> Epsilon*1000 using this custom field function, calculate volume weighted average of (epsilon*1000). Now compare the both the values, they will not differ by an multiplying factor of 1000. why? If anybody has faced this type problem, please let me know. |
August 1, 2002, 08:13 |
Re: Is it a fluent bug???
^ is a power, * is a multiplication !
August 4, 2002, 10:50 |
Laika.. pl. help
hi, i am also facing similar type of problems. Hereby i request Mr. Laika to help... will you?
August 5, 2002, 10:14 |
what values do you get?
Laika, still orbiting |
August 14, 2002, 12:52 |
Re: Laika.. pl. help
hi, sorry for late reply. I tried the same. but getting different values. I think fluent 5.5 has this bug. You can also try and see. pl. reply as early as possible.
waiting... |
August 15, 2002, 13:18 |
hi, presently my server is down due to some problem. within 2-3 days it will be ok. hence i will give values after that. thanks.
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
