August 26, 2002, 05:36 |
Symmetry Question
I'm currently working on 3D pipe flow problems, and, in order to reduce computation time, I've modelled this as a half pipe with a plane of symmetry. When reporting values such as pressure drop, should I have to double the value which Fluent reports to get meaningful numbers? Cheers, Rex |
August 26, 2002, 14:20 |
Re: Symmetry Question
Hi Rex,
You needn't do that.Just a piece of advice.Would it not be more efficient to model the case as an axisymmetric problem? Regards, sri |
August 27, 2002, 03:46 |
Sri,
What are the differences when setting the BC to symmetry as opposed to axisymmetric? Rex |
August 27, 2002, 11:17 |
Hi Rex,
Axisymmetric ==>2d model of a 3d problem. where as symmetry bc can be used either in 2d or in 3d. sri |
New Cutcells method Ansys 13 symmetry problem and doubt | William D Acosta | ANSYS | 1 | June 8, 2011 10:33 |
Simple Question Regarding Symmetry Planes | Atella | CFX | 3 | April 11, 2010 06:44 |
Simple Question Regarding Symmetry Planes | Atella | Main CFD Forum | 0 | April 9, 2010 10:58 |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 08:11 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
