mass imbalance(urgent)
Old   March 4, 2003, 22:27
Default mass imbalance(urgent)
Ross
Hi, My system is 2D axisymmetric geometries,density is constant.In the outlet,I want to check whether mass balance, the following is some report from Fluent:
x-coordinate: 1.77E-20 y-coordinate: 2.90E-04 axial-velocity: -7.29E-03 radial-velocity: -1.23E-03 mass-imbalance: -2.23E-16 daxial-velocity-dx :5.06E+01 dradial-velocity-dx:9.88E+00 daxial-velocity-dy :-6.96E+01 dradial-velocity-dy:-3.24E+01
Anyon can tell me how to calcalate the mass balanceof this point?
Old   March 5, 2003, 05:13
Default Re: mass imbalance(urgent)
Chris
To check mass balance, you can go to REPORT, then FLUX and then select mass balance...Choose the surfaces to compare and then click on COMPUTE. You should get the mass balance between both surfaces.
(sorry if that's what you've already done...I don't have access to FLUENT at the moment, and I cannot remember where you get these co-ordinates and velocities)
Hope that helps
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
