March 8, 2003, 18:04 |
a clear flow chart of LES procedure?
Dear all,
I am recently studying LES. Do you think which entry-level introduction book/thesis/paper is best for a beginner? I read some classic LES review-type books, but those books are too concise to follow. I like to see a clear flow chart clearly discribing the whole procedure. An example code (2D is good enough) will be best. I learned how to program CFD codes with Finite Volume method, k-e model, SIMPLE algo and used FLUENT for several years. Thank you very much! John |
March 12, 2003, 09:01 |
Re: a clear flow chart of LES procedure?
Hi John,
In my opinion, "Turbulent flows" by Stephen B. Pope (Cambridge university press 2001) is an excellent book. there is a whole chapter devoted to LES. For numerical codes you can see "Fluid Flow phenomena" by Paolo Orlandi (Kluwer publisher 2000). many sources code (especially finite difference approach) for LES and DNS are provided. |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
LES channel flow | ilia | OpenFOAM Running, Solving & CFD | 7 | April 18, 2011 16:58 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Turbulent Flow in a Square Duct using LES | Hock Ming | FLUENT | 0 | February 7, 2009 20:25 |
Signal decay in les channel flow | pankaj saha | Main CFD Forum | 0 | July 25, 2008 12:34 |
