Compiling UDF
Old   March 18, 2003, 09:36
Default Compiling UDF
Rahul
Hi all, I am using complie UDF in fluent6.0. When I type nmake to compile UDF, Fluent is unable to open udf.h file. Could anyone give me reason behind it. I feel I have to give some path or some thing.
Thank in advance. Rahul
Old   March 18, 2003, 20:45
Default Re: Compiling UDF
Alex Munoz
Hello
I have couple of suggestion!
first, check the compilor of your Unix machine has been install.
second, delete your library setup and do it again
third, remember to change the mode of your makefile from read to write.
fourth, copy your code under the src directory
fifth, add the name of the source code in your makefile, and verify you fluent inc path.
sixth, identify the architecture of your machine
seventh, execute your library in this way make "FLUENT_ARCH=aix51" where aix51 could be the architecture of your machine
eighth, if you still have problem, copy a UDF from the Fluent webside and replaced by your code temporarely.
nineth, if you still experiment problem, copy a UDF from fluent and interpreted by fluent instead of compiling.
Best Regards Alex
Old   March 20, 2003, 10:36
Steven
Wow, that's a lot, Alex.
I have another problem with Fluent. Every time when I start Fluent, I cannot let it read a .msh or .grd file directly. I have to read a case file first, and then it will be able to read any compatible files, like .msh file, etc. My feeling is that I may need to make some adjustment in the setup, but I couldn't find those options. Anyone has experience with it? Thanks a lot.
Steven
Old   March 23, 2003, 05:12
Rahul
Thanks alex for your help. Sorry for late reply. Regards, Rahul
compiling my Udf noa Fluent UDF and Scheme Programming 8 November 7, 2018 20:08
compiling udf at window Nt(64BIT) noa FLUENT 3 July 29, 2014 23:01
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
