June 3, 2003, 11:12 |
ICEM & GAMBIT
is it possible to import gambit mesh or ( geometry )from ICEM?..if possible can some one list the step? Thanx.. |
June 8, 2003, 20:59 |
Re: ICEM & GAMBIT
Any comment?
June 9, 2003, 04:56 |
Re: ICEM & GAMBIT
Did you try to import igeas? What are you talking about ICEM2Gambit or Gambit2ICEM?
Regards |
June 9, 2003, 06:29 |
Re: ICEM & GAMBIT
Gambit to ICEM
June 10, 2003, 04:56 |
Re: ICEM & GAMBIT
Did you try to export geometry in IGEAS CAD format?
Regrds, ff |
June 13, 2003, 10:36 |
Re: ICEM & GAMBIT
In Gambit export geometry as ACIS. The file extension will be sat i.e filename.sat. In ICEM, use import ACIS to Tetin option.
June 14, 2003, 20:15 |
Re: ICEM & GAMBIT
Thanks ff and Amadou, It works..but still long way with ICEM,,bye.
June 19, 2003, 11:00 |
Re: ICEM & GAMBIT
if you want to import Gambit mesh into ICEM MED in order to improve its quality, and/or do some changes to it, then you can, while in Gambit, choose the one of the solvers whose mesh ICEM reads/(found under Import Mesh). Or you can read this mesh in T-Grid and export it in more options than Gambit provides.
if you want to import geometry file from Gambit to ICEM, you can import it in IGES format, in a form of solid files such as ACIS, Parasolid files, but you have to have/(pay for) a license for these geometry converters (interfaces). As well, you ca use STL or other faceted geometry presentation files to directly create Tetin file (found in Geometry/Import) if you need reversed actions to do, i.e. to start from ICEM and finish them in Gambit,let us know. anna |
June 24, 2003, 06:51 |
Re: ICEM & GAMBIT
Thanks anna,
Can you please give the details of the reversed action? Jim |
[ICEM] Gambit to Openfoam, Gambit to ICEM to Openfoam | Rickard.Solsjo | ANSYS Meshing & Geometry | 7 | November 30, 2011 10:20 |
Gambit extracting & ICEM | hashem_1064 | ANSYS Meshing & Geometry | 2 | October 22, 2009 02:19 |
Gambit mesh file import into ICEM CFD | dev.... | FLUENT | 2 | January 29, 2009 10:37 |
Help: mesh conversion from Gambit to ICEM | sarah_ron2002 | FLUENT | 2 | April 5, 2008 01:53 |
How to export gambit model to ICEM | Nirupama | Main CFD Forum | 1 | October 28, 2006 13:06 |
