ICEM & GAMBIT
Old   June 3, 2003, 11:12
Default ICEM & GAMBIT
Jim Clancy
is it possible to import gambit mesh or ( geometry )from ICEM?..if possible can some one list the step? Thanx..
Old   June 8, 2003, 20:59
Default Re: ICEM & GAMBIT
Jim Clancy
Any comment?
Old   June 9, 2003, 04:56
ff
Did you try to import igeas? What are you talking about ICEM2Gambit or Gambit2ICEM?
Regards
Old   June 9, 2003, 06:29
Jim Clancy
Gambit to ICEM
Old   June 10, 2003, 04:56
ff
Did you try to export geometry in IGEAS CAD format?
Regrds, ff
Old   June 13, 2003, 10:36
Amadou Sowe
In Gambit export geometry as ACIS. The file extension will be sat i.e filename.sat. In ICEM, use import ACIS to Tetin option.
Old   June 14, 2003, 20:15
Jim Clancy
Thanks ff and Amadou, It works..but still long way with ICEM,,bye.
Old   June 19, 2003, 11:00
anna
if you want to import Gambit mesh into ICEM MED in order to improve its quality, and/or do some changes to it, then you can, while in Gambit, choose the one of the solvers whose mesh ICEM reads/(found under Import Mesh). Or you can read this mesh in T-Grid and export it in more options than Gambit provides.
if you want to import geometry file from Gambit to ICEM, you can import it in IGES format, in a form of solid files such as ACIS, Parasolid files, but you have to have/(pay for) a license for these geometry converters (interfaces). As well, you ca use STL or other faceted geometry presentation files to directly create Tetin file (found in Geometry/Import)
if you need reversed actions to do, i.e. to start from ICEM and finish them in Gambit,let us know.
anna
Old   June 24, 2003, 06:51
Ahmed
Thanks anna,
Can you please give the details of the reversed action?
Jim
[ICEM] Gambit to Openfoam, Gambit to ICEM to Openfoam Rickard.Solsjo ANSYS Meshing & Geometry 7 November 30, 2011 10:20
Gambit extracting & ICEM hashem_1064 ANSYS Meshing & Geometry 2 October 22, 2009 02:19
Gambit mesh file import into ICEM CFD dev.... FLUENT 2 January 29, 2009 10:37
Help: mesh conversion from Gambit to ICEM sarah_ron2002 FLUENT 2 April 5, 2008 01:53
How to export gambit model to ICEM Nirupama Main CFD Forum 1 October 28, 2006 13:06
