Thermal contact resistance without meshing it?
Old   June 28, 2003, 15:53
Default Thermal contact resistance without meshing it?
rosco
Is it possible with FLuent 6.1 to define a thermal resistance between 2 surfaces without mesh the goop(for example 0.04°C/W for a given area)? Like a 1D conduction..
Because I have 2 surfaces with a gap filled with thermal grease, the tickness of the thermal interface is about 0.05mm so I want to avoid create it in gambit to mesh it, it's too small..
Any idea? Thx
Old   June 30, 2003, 16:58
Default Re: Thermal contact resistance without meshing it?
Evan Rosenbaum
If the rest of your geometry will allow it, make the thermal interface thickness larger and increase the contact conductance by the same amount in the thickness direction. It isn't entirely correct, but the results may be anyway.
Old   June 30, 2003, 17:50
rosco
Thx for answer but with this way I must mesh the interface and I want to avoid that :/
how to use contact resistance model in floEFD eggliang FloEFD, FloWorks & FloTHERM 4 August 5, 2011 00:36
Variable Thermal Contact Resistance octavyo CFX 3 March 13, 2011 11:11
handle thin material or thermal contact resistance sven82 OpenFOAM 3 February 21, 2011 07:43
[ICEM] Meshing Contact Surfaces sandeep_tu ANSYS Meshing & Geometry 0 October 20, 2010 14:00
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
