IC piston motion - deforming meshes
Old   September 16, 2003, 13:10
Default IC piston motion - deforming meshes
AMV
I am trying to solve the ic engine problem. I am solving only motored flow in axi-symmetric geometry with flat piston. I observed that , if I start the simulation at TDC then as the piston reaches BDC, the velocity of the piston at BDC is not reduced to zero. The piston velocity reduces to zero after theta > 180 which is not acceptable. Can anyone explain as to how to come out of this situation ? Any hint/help is sincerely appreciated.
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 01:40
simulation of piston motion inside a hydraulic cylinder mosman FLUENT 0 August 6, 2011 15:44
Mesh Motion (Piston valve) AliAli CFX 8 October 13, 2009 05:40
Mesh Motion (Piston valve) AliAli CFX 0 October 10, 2009 10:55
