October 29, 2003, 05:05 |
Plot temperature profile
does anyone know how to plot a temperature profile during the calculation? I tried to use the plot command in the execute commands menu but it doesnt work.I know how to display a temperature contours this way but not how to plot it. I believe it should be straightforward, hopefully. thank you very much for your answer(s) David |
October 30, 2003, 06:22 |
Re: Plot temperature profile
noone knows how to plot a temperature profile during calculation in the execute commands menu? if you know, please inform me thanks |
October 30, 2003, 12:12 |
Hi
The example on Fluent 6.0 Tutorial Chap. 15 (VOF Model) Sec. 7 describes how to plot the variation of 'axial velocity' during iteration. I think, you can use the same logic to get the temperature plot, if you would like to monitor the temperature at a point during simulation. Hope this helps, Chendhil. |
October 31, 2003, 06:30 |
Re: Injection point
Hi Chendhill,
thank you very much for your help. However, it gives me a temperature plot in function of time when i want to get a temperature profile evolution during the iterations to see the influence of difference parameters I want to change. I just found out i have to use animate functions which is very interactive and gives a lot of functions. Concerning your problem with hollow spray I'm not sure, I have used DPM models but not spray but maybe you have to set your injection points on surface as you might have set it/them on the crown of your injector. I might use this model later on, so if you didnt find or didn't get a proper answer and i get a clear answer I will let you know. Hope this helps thanks again and best regards David |
July 24, 2017, 05:35 |
ashutosh jaiswal
hey
i made a geometry of 2d flow between parallel plates. from graphics and animation i want to draw contour between temperature and total temperature. but it is not showing on the other hand velocity and stream function is showing clearly. can any tell me how i can plot total temperature profile |
UDF for a horizontal temperature profile | CD | Fluent UDF and Scheme Programming | 9 | May 6, 2018 12:13 |
Please Help! Temperature profile UDF for 3D geometry | subhankar_bhandari | FLUENT | 2 | April 16, 2011 05:30 |
Help please! UDF for Temperature profile in 3D | subhankar_bhandari | Fluent UDF and Scheme Programming | 2 | August 16, 2010 08:37 |
how to set temperature profile in atmospheric boundary layer | vickrenz | FLUENT | 0 | September 16, 2009 13:26 |
velocity and temperature profile | vickrenz | FLUENT | 0 | August 30, 2009 23:58 |
