semi-transparent wall
Old   January 29, 2004, 04:14
Default semi-transparent wall
Trilok
Hi Friends, I am using Discrete ordinates model for my radiation heat transfer problem. I have one semi transparent wall. If i specify a medium as semi-transparent, how will FLUENT calculate the fraction of transimissivity? (i.e how will it calculate the fraction of radiation passing through)
say, radiation source is inside a box. and i have to analyse 2 cases: (both cases, face 1 is same material) case (i) face 1 allows 95% light to pass through case (ii) face 1 allows only 20% light to pass through how do i simulate the two cases? i mean, where will be the difference in transmissivity be fed??
Thanks in advance Trilok
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Wall functions? Pr Main CFD Forum 7 April 8, 2004 06:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
